Ademco Lynxr sytem
Old 04-28-04, 07:32 AM
cgar's Avatar
Ademco Lynxr sytem
To replace the batteries in the wireless devices, is a mainenance code required (to disable the tamper feature of each device) or can the same be accomplished by just disabling that zone.
The same is true for removing the main panel. I am painting and would like to remove the panel temporarily so that painting is easier. Do I just need to make sure the system is disabled?
Old 04-28-04, 03:12 PM
You actually have to go into installer programming to disable the tampers - the best thing to do is just call your monitoring company and tell them you are going to change your batteries and to put your system on test.
When you're done, call them back and make sure they received the signals - this also is a good way to test the system.
Good luck!
Old 05-13-04, 09:23 AM
fredtech
Yes ....you could also just unplug the transformer and disconnect the battery pack.....then remove the sensors , paint...let dry and reinstall them and then repower the system.
you will probably just need to reset the systems time and date but you will not lose any of the programming
Hope this helps
