AT&T Alarm
AT&T Alarm
Hello,
I am trying to utilize my AT&T 8720 system and can't seem to get the keypads to register a status to the control panel. I think all the codes are accurate but when I use the # pad with the code and hit Home /Away ect nothing happens..The Keypads beep when I enter the #'s and shut the door. The control panel sounds an alarm with the # of the exit showing up but I still cannot punch in the #'s and silence it or reset... Any help on why this is? Can I reset the unit...I think the previous owners had it set up with a monitoring company and phone line attached... There is also two wires that are not attached to anything leading out of the control panel attached to screws marked hard wired sensor Not sure what to do with them?? Any advice offered is appreciated
Thanks...HS
Thanks...HS
AT&T Alarm
No Problem...I have been having the same difficulty...I did find an owners manual and it says Security System 8000 but no information as to how to default set it or anything related to codes used ...The 8720 # came from the inside panel of the central controller...If you find anything please send my way...
Thanks for the reply...
HS
HS
See if this helps:
BASICS:
Zones 32 (0 to 31) all are Wireless
Batteries 12 volt rechargeable Gel-Cell in main panel, all sensors are 9-volt Alkaline
Downloadable Only to Dialer, NOT to disarm or program User Codes and Zones
Panic Button Police, press 2 square keys by ALARM logo on keypad
Arm Home 3-digit code + HOME (System beeps once, Panel shows -H)
(If 4 beeps one or more zones open)
Arm Away 3-digit code + AWAY + OPEN (System beeps once, Panel shows -A)
Disarm 3-digit code + OFF (System beeps once, Panel shows -0)
Silence Alarm 3 digit code + OFF
Reset Alarm Press CLEAR DISPLAY on Main Control Panel
Reset Trouble Press TEST/DEMO on Main Control Panel
Bypass Open zone then arm, System will beep 4 times and auto-bypass zone
(Bypassed zone will go active again if zone is closed)
Alarm Memory Press MESSAGES, last alarm will display, press CLEAR DISPLAY to clear
Finding 1. Enter User Code then OFF at keypad (Panel beeps once, shows - 0 )
Open Zones 2. At main panel press TEST/DEMO quickly (Display shows 8. 8. )
3. Quickly press all 4 buttons at same time (Display should show ".C.C")
4. Activate sensor, beeps indicate signal strength, Display shows Zone
3 Beep = Sensor Okay
2 Beeps = Sensor wireless reception is marginal
0 Beeps = Sensor failure or Sensor Battery is dead
5. Scroll through tested zones with MESSAGES button
6. Exit by pressing TEST/DEMO again (Display shows - 0 )
Reset Smoke 3-digit code + OFF
(If this does NOT reset smoke detector set for service, smoke is bad)
Panel Displays -A = Armed Away
-H = Armed Home
-0 = Off
-0 = System is in User Test Mode
- - = No State Selected
FI = Unidentified Fire Transmitter
AA = System is in 5 minute wait mode after an alarm
CC = Main Panel Trouble
00 = Panel Low Battery
8.8. = Installer Test Mode
Signals 4/2 Format Contact ID Signal Is
11 01 Fire
22 02 Medical Panic
33 03 Environmental
44 04 Perimeter
55 05 Pir
66 06 Police Panic
77 07 Holdup
88 08 Trouble (This is Generic trouble, could be anything)
67 Cancel
68 Failure Low Battery
71 AC Fail
72 Low Battery
73 Test Battery Test
74 Sup Supervisor
75 Restore
76 Police Panic
79 Medical Panic
95 Fire Panic
96 Medical Panic
99 Police Panic
122 Silent Police Panic
253 Exit Alarm
254 TS = Download Complete
<HR>
CODES:
Master Code Only one 3-digit User Code, no Secondary Codes
Hostage/Duress 3-digit code backwards
Change Code 1. Enter User Code then OFF at keypad (Panel beeps once, shows - 0 )
2. Press TEST/DEMO for 3 seconds (Display shows - 0 . )
2. Open keypad (Siren may sound but thats OK)
3. User Code is set by moving 3 wires in keypad under battery
Blue = 1st digit of code
White = 2nd Digit
Yellow = 3rd Digit
There are 10 holes labled 0 to 9, insert wires in sequence for Code
4. Press TEST/DEMO again to exit (Display shows - 0 )
<HR>
TROUBLES:
Reset Trouble (System beeps twice every 40 seconds)
1. Press MESSAGES on Control Panel to display trouble
(NO CHECK IN or LOW BATTERY or AC POWER light show, Zone will display)
2. Press MESSAGES to display other problems or CLEAR DISPLAY to erase
3. Press TEST/DEMO to exit
Silence Trouble Pressing TEST/DEMO silences trouble beeps for 15 hours
Changing 1. Enter User Code then OFF at keypad (Panel beeps once, shows - 0 )
Batteries 2. Press TEST/DEMO for 3 seconds (Display shows - 0 . )
3. Open Sensor cover and replace Battery (Siren may sound but thats OK)
Zone Testing 1. Enter User Code then OFF at keypad (Panel beeps once, shows - 0 )
3 Beep - Sensor Okay
2 Beeps - Sensor wireless reception is marginal
0 Beeps - Sensor failure or Sensor Battery is dead
Smoke Detector LED fash every 7 seconds = Normal
No LED flash = Smoke not functioning
Beeps Rapidly = Low Batteries
Panel Displays -A Armed Away
-H Armed Home
-0 Off
-0. System is in User Test Mode
- - No State Selected
FI Unidentified Fire Transmitter
AA Disarm Period (Panel is in a 5 minute wait mode)
CC Main Panel Trouble
00 Panel Low Battery
8.8. Installer Test Mode
11 01 Fire
22 02 Medical Panic
33 03 Environmental
44 04 Perimeter
55 05 Interior
66 06 Police Panic
77 07 Holdup/Ambush
67 Cancel
71 AC Fail
72 Low Battery
74 Sup Supervisor
75 Restore
76 Police Panic
79 Medical Panic
95 Fire Panic
96 Medical Panic
99 Police Panic
<HR>
PROGRAMMING:
Add Sensor Set dip switches on sensors, panel will "see" any sensor with same House Code
Delete Sensor 1. Power panel down
2. Remove sensor batteries, change House Code dip switches of sensor to delete
2. Power system up, nothing else is needed
<HR><HR>
Good Luck!
BASICS:
-H = Armed Home
-0 = Off
11 01 Fire
22 02 Medical Panic
33 03 Environmental
44 04 Perimeter
55 05 Pir
66 06 Police Panic
77 07 Holdup
67 Cancel
71 AC Fail
72 Low Battery
74 Sup Supervisor
75 Restore
76 Police Panic
79 Medical Panic
95 Fire Panic
96 Medical Panic
99 Police Panic
253 Exit Alarm
<HR>
CODES:
White = 2nd Digit
Yellow = 3rd Digit
<HR>
TROUBLES:
-H Armed Home
-0 Off
11 01 Fire
22 02 Medical Panic
33 03 Environmental
44 04 Perimeter
55 05 Interior
66 06 Police Panic
77 07 Holdup/Ambush
67 Cancel
71 AC Fail
72 Low Battery
74 Sup Supervisor
75 Restore
76 Police Panic
79 Medical Panic
95 Fire Panic
96 Medical Panic
99 Police Panic
<HR>
PROGRAMMING:
<HR><HR>
Good Luck!
I see why these puppies dropped off the map so soon after they were introduced in the late 80's.
It's better than nothing, but only just. I actually found one of the keypads buried in our "in case of desperation" parts closet but the docs were long gone.
Thanks
ThankYou both..Now I realize why I was having such problems especially without much experience in these systems. I will try to configure by following the listing of what you sent Brandon and post my success or not after giving it a try..
Thanks Again...
HSHS
Thanks Again...
HSHS
