Dsc Pc2500
Dsc Pc2500
Looking for installation manual for PC2500. Does it install (program) like the PC2550 ?
Nope, they program differently:
<hr>
Programming:
Enter Program * 8 2500 or 2530 (READY, ARMED and SYSTEM Lights should flash)
If this doesn't work look under EMERGENCY NETWORKS for Installer Code
Exit Program #
Move to location Enter 2-digit location
Default Panel Short "EEPROM RESET" pins on board, power up. Can't be locked out
Hex Program A = * 1 * B = * 2 * C = * 3 * D = * 4 * E = * 5 * F = * 6 *
Zone Page TECH1 Click HERE for List of what below programming will report
[01] Receiver Phone 1 (15 Digits Maximum)
I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I _ _I
* 2 * = HEX B - to dial *
* 3 * = HEX C - Insert a 4-second pause
* 4 * = HEX D - Wait for Dial-Tone
* 5 * = HEX E - to dial #
[02] Account Number 1
Note: Any 0 must be entered as *1* 00 is *11*
[03] Receiver Phone 2 (15 Digits Maximum)
[04] Account Number 2
[05] Zone Alarm Report Codes 1 to 8
I _3 _I _1 _I Zone 1 Alarm I _3 _I _5 _I Zone 5 Alarm
I _3 _I _2 _I Zone 2 Alarm I _3 _I _6 _I Zone 6 Alarm
I _3 _I _3 _I Zone 3 Alarm I _3 _I _7 _I Zone 7 Alarm
I _3 _I _4 _I Zone 4 Alarm I _3 _I _8 _I Zone 8 Alarm
[06] Zone Restoral Report Codes 1 to 8
I _0 _I _0 _I Zone 1 Restoral I _0 _I _0 _I Zone 5 Restoral
I _0 _I _0 _I Zone 2 Restoral I _0 _I _0 _I Zone 6 Restoral
I _0 _I _0 _I Zone 3 Restoral I _0 _I _0 _I Zone 7 Restoral
I _0 _I _0 _I Zone 4 Restoral I _0 _I _0 _I Zone 8 Restoral
[07] Utility Alarm Report Codes
I _1 _I _6 _I Fire Zone Alarm I _0 _I _0 _I Foil Zone Trouble
I _0 _I _0 _I Aux Input Zone Alarm I _0 _I _0 _I Bell Circuit Trouble
I _0 _I _0 _I Battery Trouble I _7 _I _6 _I Fire Zone Trouble
I _7 _I _9 _I AC Failure Trouble I _0 _I _0 _I Aux Power Supply Trouble
Low Battery report removed due to tendency for runaway signals
[08] Utility Restoral Report Codes
I _0 _I _0 _I Fire Zone Restoral I _0 _I _0 _I Foil Zone Restoral
I _0 _I _0 _I Aux Input Zone Restoral I _0 _I _0 _I Bell Circuit Restoral
I _0 _I _0 _I Battery Restoral I _0 _I _0 _I Fire Zone Trouble Restoral
I _0 _I _0 _I AC Fail Trouble Restoral I _0 _I _0 _I Aux Power Supply Trouble
[09] Closing (Arming) Report Codes 1 to 8 (If Closing required use 61 62 63 64 65 66 67 00)
I _0 _I _0 _I Access Code 1 I _0 _I _0 _I Access Code 5
I _0 _I _0 _I Access Code 2 I _0 _I _0 _I Access Code 6
I _0 _I _0 _I Access Code 3 I _0 _I _0 _I Access Code 7
I _0 _I _0 _I Access Code 4 I _2 _I _6 _I Access Code 8 (Duress)
[10] Opening (Disarming Report Codes 1 to 8 (If Opening required use 51 52 53 54 55 56 57 26)
[11] Miscellaneous Report Codes
I _0 _I _0 _I Partial Closing I _0 _I _0 _I Keypad Police Panic Restoral
I _2 _I _9 _I Keypad Police Panic I _0 _I _0 _I Keypad Fire Panic Restoral
I _1 _I _9 _I Keypad Fire Panic I _0 _I _0 _I Keypad Medical Panic Restoral
I _4 _I _9 _I Keypad Medical Panic I _0 _I _0 _I Periodic Test Transmission
[12] Zone Definitions for Zones 1 to 8
I _ _I _ _I Zone 1 00 = Delay
I _ _I _ _I Zone 2 01 = Instant
I _ _I _ _I Zone 3 02 = Standard Motion
I _ _I _ _I Zone 4 03 = Motion Home/Away (Auto Bypass)
I _ _I _ _I Zone 5 04 = 24 Hr Bell
I _ _I _ _I Zone 6 05 = 24 Hr Bell/Buzzer
I _ _I _ _I Zone 7 06 = 24 Hr Buzzer
I _ _I _ _I Zone 8 07 = 2x Delay
08 = 4x Delay
09 = Foil
[13] 1st System Option Code (Toggle Options ON/OFF, Press # to Exit)
Option ON OFF
OFF I OFF_I 1 Restorals Follow Zone Disabled
OFF I OFF_I 2 Restorals on Bell Time out Disabled
OFF I OFF_I 3 Restorals on Disarming Disabled
OFF I OFF_I 4 DTMF Dialing Pulse Dialing
OFF I _I 5 Normally Closed Loops EOL Resistors Loops
OFF I OFF_I 6 Keypad Panic Audible Silent
ON I _ON _I 7 Call 1st Phone Only Backup to 2nd Phone
OFF I OFF_I 8 8th Code Maids Code Normal Code
[14] 2nd System Option Code (Toggle Options ON/OFF, Press # to Exit)
Default Option ON OFF
OFF I OFF_I 1 For Future Use
OFF I OFF_I 2 For Future Use
OFF I OFF_I 3 For Future Use
OFF I OFF_I 4 For Future Use
OFF I OFF_I 5 Not Used
OFF I OFF_I 6 1400 Hz Radionics 2300 Hz Radionics
OFF I OFF_I 7 TLM Disabled TLM Enabled
OFF I OFF_I 8 Code Required for Bypass Code not Required
[15] Zones 1 to 8 Bypass Mask (Toggle Options ON/OFF, Press # to Exit)
ON I _ON _I 1 Zone 1 Bypass Enable Bypass Disable
ON I _ON _I 2 Zone 2 Bypass Enable Bypass Disable
ON I _ON _I 3 Zone 3 Bypass Enable Bypass Disable
ON I _ON _I 4 Zone 4 Bypass Enable Bypass Disable
ON I _ON _I 5 Zone 5 Bypass Enable Bypass Disable
ON I _ON _I 6 Zone 6 Bypass Enable Bypass Disable
ON I _ON _I 7 Zone 7 Bypass Enable Bypass Disable
ON I _ON _I 8 Zone 8 Bypass Enable Bypass Disable
[16] System Times
Default
30 I _3 _I _0 _I Entry Delay (00 to 99 seconds)
60 I _6 _I _0 _I Exit Delay (00 to 99 seconds)
04 I _0 _I _4 _I Bell Cutoff (00 to 99 minutes)
60 I _6 _I _0 _I AC Fail Transmission (00 to 99 minutes)
75 I _7 _I _5 _I Loop Response (00 to 99 ms.)
30 I _3 _I _0 _I Test Transmission Cycle (00 to 99 days)
[17] System Clock Times
Default
9999 I _9 _I _9 _I _9 _I _9 _I Automatic Arming Time of Day
9999 I _9 _I _9 _I _9 _I _9 _I Test Transmission Time of Day
[18] Installer Code
Default
2500 I _2 _I _5 _I _0 _I _0 _I (Also try 2530)
[19] Master Code
Default
1234 I _ _I _ _I _ _I _ _I
[20] For Future Use
[21] Communication Format (Any Underlined format will work)
Default
1 I _1 _I 1st Telephone Number
1 I _1 _I 2nd Telephone Number
[0] Silent Knight/Ademco slow, 10 BPS (1400 Hz handshake) 3/1, 4/1, 4/2 non-ext
[1] Sescoa, Franklin, DCI, Vertex, 20 BPS (2300 Hz handshake) 3/1, 4/1, 4/2 non ext
[2] Silent Knight fast, 20 BPS (1400 Hz handshake) 3/1 and 4/2 non extended
[3] Radionics, (2300/1400 Hz handshake) 3/1 and 4/2 non extended
[4] Radionics, (2300/1400 Hz handshake) 3/1 and 4/2 non extended with parity
[5] Acron 4/2 Superfast
[6] Ademco 4/2 Superfast
[7] For future use
[8] Silent Knight/Ademco slow, 10 BPS (1400 Hz handshake) 3/1 extended
[9] Sescoa, Franklin, DCI, Vertex, 20 BPS (2300 Hz handshake) 3/1 extended
[A] Silent Knight fast, 20 BPS (1400 Hz handshake) 3/1 extended
[B] Radionics, (2300/1400 Hz handshake) 3/1 extended
[C] Radionics, (2300/1400 Hz handshake) 3/1 extended with parity
[D] For future use
[E] For future use
[F] For future use
[22] PGM Output
Default
22 I _1 _I _8 _I
1st Digit = Auxiliary Input Zone 2nd Digit = Programmable Output
0 = Future Use 0 = Not Used
1 = Silent 24 Hour Input 1 = Ground Start Pulse
2 = Audible 24 Hour Input 2 = Utility Output no Access Code
3 = Momentary Key Arming 3 = Utility Output any Access Code
4 = Utility Output Group A Access Code
5 = Utility Output Group B Access Code
6 = Keypad Buzzer Follow Mode
7 = System Status (Arm/Disarm) Output
(* 4 Resets Smoke) -->> 8 = Strobe Output (Latched Alarm Output)
9 = Failure to Communicate Output
A = For Future Use
B = Output from Keypad Loop
[23] Zone Group A Assignment (Toggle Options ON/OFF, Press # to Exit)
Default
ON I _ON _I Zone 1 If Zone light ON that zone is assigned to Group A
ON I _ON _I Zone 2
ON I _ON _I Zone 3
ON I _ON _I Zone 4
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
[24] Zone Group B Assignment (Toggle Options ON/OFF, Press # to Exit)
Default
ON I _ON _I Zone 1 If Zone light ON that zone is assigned to Group B
ON I _ON _I Zone 2 If a Zone light is on in both 23 and 24 that zone is
ON I _ON _I Zone 3 common to both partitions and will arm if both
ON I _ON _I Zone 4 sides are armed
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
[25] Access Code Group A Assignment (Toggle Options ON/OFF, Press # to Exit)
Default
ON I _ON _I Zone 1 If Zone light ON that Access Code is assigned Group A
ON I _ON _I Zone 2
ON I _ON _I Zone 3
ON I _ON _I Zone 4
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
[26] Access Code Group B Assignment (Toggle Options ON/OFF, Press # to Exit)
Default
ON I _ON _I Zone 1 If Zone light ON that Access Code is assigned Group B
ON I _ON _I Zone 2 If Zone light is on in both 25 and 26 that code is common
ON I _ON _I Zone 3 to both sides and will arm or disarm the entire system
ON I _ON _I Zone 4
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
[27] Communicator Call Direction
Default
1 I _ 1 _I Zone Group A Alarms and Restorals 0 = No Transmissions (Disabled)
1 I _ 1 _I Zone Group B Alarms and Restorals 1 = Call 1st Phone, Backup to 2nd
1 I _ 1 _I Access Codes Group A Openings/Closings 2 = Call 2nd Phone Only
1 I _ 1 _I Access Codes Group B Openings/Closings 3 = Always Call Both Number
1 I _1 _I Priority Alarms and Restorals
1 I _1 _I Maintenance Alarms and Restorals
[28] Reset To Factory Defaults (USE ONLY IF ERASING PROGRAMMING)
[50] EEPROM Copy Function
Codes
Master Code User 1
Secondary Codes User 2 to 7
Duress Code User 8
Add Code 1. Press * 5 + Master Code (READY/ARMED/TROUBLE will flash)
2. Enter User (1 to 8) (Zone light will begin flashing)
3. Enter new 4-digit User Code (Zone light stops flashing and turns ON)
4. Press # to exit
Delete Code 1. Press * 5 + Master Code (READY/ARMED/TROUBLE will flash)
2. Enter User (2 to 8) (Zone light will begin flashing)
3. Press **** (Zone light should turn OFF)
4. Press # to exit
Troubles
View Trouble Press * 2 and zone light will turn on showing trouble
Zone Light 1 = Panel Low Battery
Zone Light 2 = AC Failure
Zone Light 3 = Day Loop Trouble
Zone Light 4 = Telephone Line Failure (only if Phone line Monitoring is enabled)
Zone Light 5 = Failure to Communicate
Zone Light 6 = Bell/Horn Fuse Failure
Zone Light 7 = Smoke Detector Trouble (must power down system)
Zone Light 8 = System Clock
To set time - * 6, Master Code, 1 then 4 digits (Military Time)
If no lights show system needs service
<hr>
Hope that helps. If you need any other help, let us know.
<hr>
Programming:
Exit Program #
08 = 4x Delay
09 = Foil
Option ON OFF
[16] System Times
Default
Default
[18] Installer Code
Default
[19] Master Code
Default
[20] For Future Use
Default
[7] For future use
[D] For future use
[E] For future use
[F] For future use
[22] PGM Output
Default
22 I _1 _I _8 _I
A = For Future Use
Default
ON I _ON _I Zone 2
ON I _ON _I Zone 3
ON I _ON _I Zone 4
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
Default
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
Default
ON I _ON _I Zone 2
ON I _ON _I Zone 3
ON I _ON _I Zone 4
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
Default
ON I _ON _I Zone 4
ON I _ON _I Zone 5
ON I _ON _I Zone 6
ON I _ON _I Zone 7
ON I _ON _I Zone 8
Default
Codes
Master Code User 1
Duress Code User 8
4. Press # to exit
4. Press # to exit
Troubles
<hr>
I just ran across one today - couldn't do anything with it. It was completely locked-out. Oh well, they are cheap to replace.
I think most companies used the 1500 or 1550 versions of the DSC panels. I run across a 2550 every now and then, but not too often.
This isn't one that looks to have pager-type output. You would likely have to use a voice dial unit.
It was an uncommon unit. Generally, the 5010 (Power 832) was a better choice for an 8 zone panel, and the price difference was pretty minimal. I've run into exactly one in the wild.
pc2500
Hi MrRon
I got the system from my son, who upgraded his new house. I'm an old retired telephone man that likes to dable and thought I'd try it in my place if i could get it to work. Brandon steered me in the right direction and I have it working. I have it set to call my cell phone, but it keeps on calling. Is there a way to limit the number of out going calls?
I kinda think it's an oddball system as I can't seem to get much info on it and DSC doesn't answer my emails.
Ken
Ken
Security panel builders don't provide anything other than user manuals for non-dealers (for obvious reasons).
As far as the dialout, there is no option to limit the number of attempts (it's probably hard-coded for 8-10 trys). If it doesn't get a "kissoff" from a reciever that it recognizes, then it will keep trying until it reaches it's comm failure limit.
Like I said, I think it didn't sell well because it's far less capable than the Power Series that first became popular about the same time (late 1980s).
