Master Code for GE Simon Control Panel
Old 08-10-04, 10:07 AM
fwashington
Question Master Code for GE Interlogix Simon Control Panel
I moved into a house with a GE Interlogix Simon Control panel was wondering how to get the system to convert back into default settings
Model # 60-693-95R
Old 08-30-04, 08:23 AM
CapeJamz
Post
If you sign up for monitoring with anyone, they will come out and reset the codes for you. You're not likely to see anyone give out a master code on line for a whole line of any security product.
Monitoring usually starts at around $29-39 per month.
Good luck.
Old 08-30-04, 02:54 PM
Received 89 Votes on 83 Posts
Please check the following thread: http://forum.doityourself.com/showthread.php?t=178565
Safewatch posted the solution earlier last week.
Old 08-30-04, 07:36 PM
Absolutely not!!! Monitoring <i>starts</i> around $10-15/month. Monitoring <i>tops</i> around $29-39/month - and that's usually with a leased or financed system (like the kind you get from ADT, Brinks, or the "free system" companies.)
To reset the code on a Simon, you'll have to default the entire panel, which means you'll also have to reprogram the system. As Ron said, see the other post which explains the steps in more detail, and provides a link to the manual (which you will need.)
Good luck!
