Master code for ITI Simon Wireless Control Panel
Old 08-24-04, 08:22 AM
fwashington
Question Master code for ITI Simon Wireless Control Panel
I have just moved into a house with an ITI Simon Wireless Control Panel model # 60-693-95R. I need some help trying to reset the master code back to default if anyone can help I would appreciate it.
Fred Washington
Old 08-24-04, 08:32 AM
You'll have to completely default the panel to reset the master code. This means you'll also have to reprogram the system.
So, you're going to need a manual for the system. You can get it at http://manuals.safewatchservice.com
Essentially what you are going to do is power the system down, then power up while holding C-C-M (Cancel-Clock-Minutes) - that will return the system to defaults.
But, don't do anything until you get the manual.
Let us know if you need some help.
