DSC WLS-902 Keypad
Old 08-25-04, 05:07 AM
mr.phillips
Talking DSC WLS-902 Keypad
I just moved and need to set up my wireless DSC system. I can not locate my original owners manual with the master code on it. I have all the components installed and working properly but I need to fix the date and assign new codes for my kids. I am using the DSC WLS-902 Keypad S/N 03361. Please help thanks.
Old 08-25-04, 04:29 PM
Received 265 Upvotes on 244 Posts
Is this another of these "Marquis" systems?
Old 08-26-04, 05:56 AM
mr.phillips
Yes it is. Help me. Please.
Old 08-26-04, 06:30 AM
The owners manual you can get from the DSC.com website. For the installer manual, you can check with someone like safewatch.
That said: If the installer code has never been changed, and you just want to retrieve the master code.
press #; at the enter access code prompt enter *8. It will prompt for installer code which is 0900 for the default. Use the "no" (arrow down) key to scroll to edit installer program. Use "yes" key to select.
At enter program section prompt, enter 04.
number in the parenthesis on the left side of line 2 in the display is the current master code.
Exit program mode by hitting # until you get back to your ready prompt.
