Vista 20p wont go into "AWAY" mode
Old 08-31-04, 11:35 AM
Keebler
When I put in my code and press "AWAY" the keypad says away exit now but after it completes the count down the siren sounds off for a quick second and goes into stay mode instead..All the sensors are working and wired properly, when I go to arm the system it says "Ready to Arm"...
Please help
Vista 20p
hardwired
1 motion sensor
6160V keypad
zone doubled
Old 08-31-04, 06:09 PM
Received 89 Votes on 83 Posts
Depending on programming, if you don't open and close an entry/exit door during the count down, interior zones will automatically bypass (thus stay arming). I'm pretty sure it's the default setting.
Old 09-07-04, 09:31 AM
Keebler
Unhappy
I tried arming the system in "AWAY" mode again and made sure I open and closed the door and it still went into armed count down then after count down the siren sounded for a short second and it went into stay mode.
Old 09-07-04, 12:25 PM
The siren sounds because you have "confirmation of arming ding" (field *38) turned on.
Are you _certain_ that the door you are exiting through is zone defined as an entry/exit (type 01 or 02).
The Auto-stay feature is turned on and off in field *84.
Old 09-10-04, 08:51 AM
Keebler
Smile
That worked excellent, thanks for your help.
