Need to replace Eagle 4700DL alarm system!
Old 09-07-04, 01:33 PM
E
I need some help in choosing a decent alarm system to replace my Eagle 4700DL alarm system. It has 5 zones which work okay but the main panel is outdated. I dont want to go wireless because there are too many windows in the house and it would be a little expensive to change all of the window and door contacts. I have recently installed an Ademco LYNX in my business and it was fairly easy. Thanks all.
Old 09-07-04, 06:18 PM
I highly recommend the GE/ITI Concord Express - it is a traditional hardwire system with 16 zone wireless built-in. So, you can wire in the zones you have (or add new ones), but you can also use wireless if you need to.
The system is also the easiest on the market to program.
Good luck!
Old 09-08-04, 08:16 AM
E
Need to replace Eagle 4700dl
Thanks for replying but how many hard wired zones does the GE/ITI Concord Express have because i need at least 6 hard wired zones. Thanks again
Old 09-08-04, 12:19 PM
Here some quick info from <a href="http://geindustrial.com/cwc/products/ge-interlogix?pnlid=9&famid=55&catid=1131&id=6-16hard&lang=en_US">GE's website</a> about the <a href="http://concordexp.safewatchservice.com">Concord Express</a>:
<b>Description</b>
Concord Express is a hardwire system integrating ITI wireless for the cost of a traditional hardwire panel. Even for typical hardwire installations, such as new construction, keychain touchpads and other wireless components add value to the system and profits to your bottom line.
<b>Features and Benefits</b>
6 hardwire and 16 wireless zones standard; can use up to 24 zones in any combination of hardwire and wireless
2 onboard programmable outputs
2- and 4- wire smoke detector compatibility
Compatable with all ITI wireless Learn Mode™ sensors
16 user-programmable access codes with user-programmable authority levels
Latchkey numeric paging
50-event history buffer
SIA False Alarm Reduction features
Old 09-08-04, 02:29 PM
E
Eagle 4700
Thanks a million. I hope it is not too complicated to install
