Wiring Help Needed
Old 10-12-04, 11:50 AM
vmodi
Wiring Help Needed
I am trying to sort my wiring out and install a new system
I have several set of wires in the control panel
1st set of 6 wires go to the keyboard
2nd set of 6 wires go to the keyboard
3rd set of 6 wires only 2 used go to the panic button in the Main Bedroom
4th set of wires only 2 used go to the indoor siren
Now I am left with 3 sets of red & white wires and 2 set of white wires.
Out of 3 sets of red & white wires 2 white wires forms a circuit and does not
affect if I open doors or windows
Other wires do not form a circuit and does not affect if I open doors or
windows.
I have 6 windows wired 2 front window 1 window in the same room on the side
1 back window 1 Bedroom window and 1 bathroom window
The magnets on this windows are not affixed parallel to the switch but they
are in diagnal position from the switch.
I have 2 doors 1 Main door and 1 garage door both had time delay entry exit
Both the doors have a press button type switch on the bottom and just above
that switch a plastic sensor with 2 wires welded on the copper contact of
the press button switch. The press button switch reads "Used for Closed Circuit"
I have 2 back doors both the doors have plastic type sensor only like the
plastic sensor on the main door except without press button switch
I have 1 outdoor siren I do not know where it is intalled
Where is an outdoor siren typically installed ?
I am trying to sort my wiring out and then install a new system
Please Help
V Modi
[email protected]
Old 10-12-04, 05:31 PM
Received 89 Votes on 83 Posts
"I have several set of wires in the control panel
2nd set of 6 wires go to the keyboard"
I assume that these are in two different locations.
"3rd set of 6 wires only 2 used go to the panic button in the Main Bedroom"
These can also be use for a keypad connection.
"4th set of wires only 2 used go to the indoor siren
affect if I open doors or windows"
Somewhere in there are the power wires that go to the system power pack, possibly there is and attic mounted siren.
"Other wires do not form a circuit and does not affect if I open doors or
windows.
are in diagnal position from the switch."
Unless they are odd switches, then the magnets are in the wrong position. They need to be within about 1/4 to 1/2 inch of the switch to work correctly.
"I have 2 doors 1 Main door and 1 garage door both had time delay entry exit
plastic sensor on the main door except without press button switch"
This one is also a magnetic switch. The magnet should be in the corresponding edge of the door.
"I have 1 outdoor siren I do not know where it is intalled
Where is an outdoor siren typically installed ?"
In the attic is a typical location, unless there is an actual exterior siren box.
