ADT panel wiring
Old 10-18-04, 06:17 PM
lrkg1234
ADT panel wiring
The control panel to my alarm system was ripped out of the wall and I need to know how to properly re-connect the wiring. The control panel is a (ADT) Safewatch Plus.
Old 10-19-04, 07:12 PM
Received 265 Upvotes on 244 Posts
Is this the keypad or the actual control?
Old 10-20-04, 07:44 AM
lrkg1234
The keypad. I have 4 wires coming out of the wall, red,yellow,black, blue. The keypad wiring is red, black, white, green.
Old 10-20-04, 03:13 PM
Make sure you power the system down first. Then:
Red - Red
Black - Black
Yellow - White
Blue - Green
That should work. If the keypad does not respond properly on power up, then swap the Yellow and Blue wires.
Good luck!
Old 10-21-04, 06:35 AM
lrkg1234
Thank you. I tried both configurations, but the keypad is totally dead on power up. Is there some way diagnostic that I can run, or can I look at the control panel wiring for a clue? I appreciate your help.
Old 10-21-04, 03:30 PM
It's not impossible that one or more of the fuses on the panel went when the wiring was damaged. If you have the means to check voltage, you can see if there is power coming into the panel from the transformer, and if there is 12 volts at the terminals that the red and black power wires for the keypad are connected to.
Old 10-22-04, 03:15 PM
lrkg1234
It was a fuse. All works good. Thank you very much for your help.
