Vista 20p "Fault 03 Line"
Old 12-05-04, 12:58 PM
Keebler
Exclamation Vista 20p "Fault 03 Line"
I have an active fault that says "Fault 03 Line" and the system wont arm, im pretty sure its not a sensor; maybe the telephone line?
Please help
Vista 20p
6160V
1 motion sensor
hardwired
Old 12-06-04, 03:03 PM
Received 265 Upvotes on 244 Posts
According to the trouble shooting chart, it may be an issue with a expander of some type. If you don't have wireless, it may be a connection on a keypad (I think some of the better keypads are logged into the system as expanders).
Old 12-06-04, 05:47 PM
Keebler
keypad works normall but still checked connections, they seemed okay. If it is an expander problem what do i look for?
Old 12-06-04, 08:45 PM
It depends on what boards are added into the system. I'd guess at one with an address of 3. A quick test to eliminate the hardwired zone 3 is to simply put a eol resistor on the zone terminals. Otherwise, on any expander boards, I'd check the communication wires that go back to the keypad bus.
Old 12-08-04, 08:54 PM
Address 3 is the default address of AlarmNetC (cell backup for the phone line). You might check to see if there are more wires on terminals 6 & 7 than there are keypads, although this is not fool-proof, since AlarmNet can be piggy backed on a keypad wire.
Old 12-09-04, 03:06 PM
If you don't have a cell backup, check to see if you accidentally turned on (entered a 1) in field *29. If so, the panel is looking for a non-existant module.
