Battery Replacement in a DSC Power 832 Security Alarm
How do you replace the battery in a DSC Power 832 Security Alarm, and can you purchase any type of 12 volt battery of the same size as the existing. The battery I have is a YUASA-Exide NP7-12. Can I purchase an equivalent at a Sears store?
Thanks
Jim
Thanks
Jim
power down the system and replace the battery, power up by plugin the battery first. after that adjst the time by pressing *5+your master code +1(the time in 24 hours format ) for 1 :23pm feb 21 2005 you enter 1323210205 than pund. you are done.
You can find those batteries at Radio Shack, your local Interstate battery dealer (most areas have one), some home centers stock them (some emergency lights also use them). If its typical, it's a 4 to 7 ah battery.
