DVR Card Video Cameras and Baluns
Old 03-02-05, 07:53 PM
Bishop
I posted here due to my question is security camera related.
I bought a DVR card for my PC with security software and baluns for use with cat 3 or 5 wire.
So far the software works the DVR security card installed correctly but no video so far.
I'm running a 350 Pentuim
Any help would be helpful
Old 03-03-05, 05:40 PM
D
ummm we would need more info to trouble shoot this, suggestions would be to try and just get a video signal from the balum right on a tv with a BNC to RCA convertor just to check the signal before you go into your PC. Are the Baluns nonpowered? you have to make sure that the lines are straight thru such as terminal 1 at one end is the same at the other, cause if you cross them the signal can freak out. Everything at the camera end is good? Power ect. Just try to connect the camera strait to a TV with the same principal as above and see if the camera is working. Start at the camera and work your way back to the PC. 2 cents from Dalsecman.
