open ckt displayed
Old 03-20-05, 02:08 PM
alex71168
open ckt displayed
i have an ademco alarm and a 6139 keypad which is displaying OPEN CKT and none of the keys do anything could some please advise on what to do to rectify this
thanks
Old 03-21-05, 08:08 AM
Received 265 Upvotes on 244 Posts
It means that the keypad cannot talk to the control. One or more of the wires either at the back of the keypad, or at the panel terminals is not connected. The worst case is the wire being damaged somewhere inbetween. Has any work been done on the system or the house? I've seen this happen from someone stepping through an attic and snagging the cable with their shoe (and then there's _squirrels_....)
Old 03-23-05, 06:58 PM
alarmman
try switching the green and yellow Key pad wires on the control.make sure the kp is wired corectly red blk grn yel.
Old 03-24-05, 05:44 AM
Also make sure it is addressed correctly for your panel. 31 for most panels. If it is a p series(2op,15p) etc it depends on how many keypads you have and you have to enable individually in system programming then address at each keypad
