Arming
Old 04-08-05, 05:24 PM
JGL97
Arming
I have A Adt safewatch pro 3000EN I'm trying to arm in maximum mode in which they would be no entry delay, and interior and perimeter would be instant. Is this possible or do I have to do a Night-Stay mode and How would I do this.
Please Advise
Old 04-08-05, 06:40 PM
Received 265 Upvotes on 244 Posts
Enter your code + 4. You will still have an exit delay (Im not sure if it gives an audible countdown). If the quick arm feature is active, just press #+4.
Old 04-08-05, 06:44 PM
JGL97
I tried that is it possible this feature is not on this panel
Old 04-08-05, 06:58 PM
First, do you have the ready light? Is there a motion directly in view of the keypad you are trying to use?
The maximum arming command should work just like the others. It _is_ possible that the ADT version of this panel has the maximum function disabled, but I rather doubt it.
Old 04-08-05, 07:04 PM
JGL97
also the 4 key on the 6150 pad is blank this is why I feel max is disabled
Old 04-08-05, 07:20 PM
Ummm, are we talking about the same "4" key? I mean the number 4 on the numeric keypad, not one of the function keys on the side. The quick keys have to be programmed for specific functions.
Old 04-09-05, 06:42 PM
JGL97
Yes the#4 key on the ADT version of the 6150 is blank
Please Advise
Old 04-09-05, 08:48 PM
In that case, that feature may not be available in this model. I know that a lot of the ADT versions of alarm panels disable common features like partitioning, so this may be the case.
Old 04-10-05, 01:47 PM
The max feature is disabled on this panel. One way you could do it if the motion you want to be instant at night is not in the path of your normal entry when entering house. You could program that motion as a perimeter. But then you need to remember to bypass it each time you want to arm in regular stay mode or instant stay mode to allow you free movement in your normal routines. Trust me I know it's a pain but I do this with mine/ This is all moot if you have to pass this motion when you enter the house and access keypad(s)
