Need Help Resetting ADT Ademo System
Need Help Resetting ADT Ademco System
I recently purchased a home that has an ADT Safewatch 3000 security system (Ademco keypads). I want to use this system without monitoring for at least a little while. I read all the posts for resetting the system, but I can't get it to work. I disconnected the power and successfully retrieved the installer code of 6321 (Big surprise!) . However, I can't seem to set the codes or do anything else useful after that. The keypad in the kitchen is the one with the voice features. I can't seem to do anything with that one. It keeps asking me for "Field?". I don't know where to go from there. I tried to use the keypad upstairs, but I only get as far as "6321 + 8" before the system interrupts me. It first beeps and displays "02". Then it displays "01", beeps a few more times and stays there. Any help would be appreciated. I also apologize in advance if this has been explained better in another post. I did a bunch of searches but didn't find anything else helpful.
You are still in program mode. To exit, enter *99. Then you will be able to use the installer code to change the master code. The installer manual you will need is for a Vista 20p. This is a pretty complex system. To navigate it you need the reference, even with the online help.
installer code + 8 + 02 + new code
That doesn't work. After I type in the '02', the display shows "Installer Code". Any help would be much appreciated. Thanks.
It should only say "Installer code 20" if you hit 6321+800. Whenever you see that, it means you are in programming, and need to hit *99 to exit before you can make changes.
Make sure it says "disarmed ready to arm" then hit
6321+802+newcode. it should beep to confirm.
Did you accidentally change the installer code from 6321? That would be one of the first things to check if the above code does not change it for you.
IJ
IJ
IJ
IJ
If I had to guess, when you key that leading 0 for the 02, you are getting a "keybounce" and the keypad is sending a 00 instead. It's the only thing that makes sense. Does it also do this when you try it from the other keypad(s)?
You are following the right steps. That key sequence should change the master code, not put you into program mode. Listen to the beeps as you key the sequence. If you hear a double beep when you press the zero, then that key may simply be sticking.
Well, it's an ADT Safewatch Pro 3000 system. The keypads look like the Vista 20P series. I have 2 regular ones and 1 with the alphanumeric display. I have the installation manual for both the Vista 10P series and the Vista 20P series. I tried the methods for both. I'm pretty sure my "0" key is not sticking and sending "00" because my installer code has a 0 in it and I am able to use that code to do the programming just fine. It seems that I am thrown into programming mode every time after I press: installer code + 8 + 0 + any other digit. I am brought to the field 20 screen in programming mode. This is really starting to irritate me.
However, I appreciate all the help I've received so far.
at your alpha keypad press 1 &3 at the same time see what address it is should be 16. then go to your additional keypads and check their addresses make sure none are duplicated if there is a duplicate address change it to 17 for the 2nd keypad 18 for the 3rd if this is all ok go to the panel and get the number off of the chip just a shot in the dark but something is not sounding correct your procedures are right but it sounds like someone may have tried to upgrade it to a vista 20p non adt which will not work
There's your answer. Power the system down by disconnecting the wire under terminal 1 in the panel, and disconnect one of the battery leads. Then power up (don't forget the battery). You have about a minute to address the keypads. Make the alpha 16 by holding down 1&3. When 31 appears, enter your 16. You may have to make it 00 first if it doesn't let you change it. Then go to the other keypads and make them 17 and 18. Go back to the alpha keypad and go into programming (installer code + 800). Hit *190, then 1,0; then hit *191, then 1,0. You keypads are now addressed and you should be able to change the master code.
OK. I changed the keypad addresses like you said. The alpha one in the kitchen now shows 16. The one upstairs shows 17 and the one in the basement shows 18. However, now I'm getting blank displays on all of them. I can still show their addresses by holding 1&3. On the alpha one, I can change the address and do 3 other things: turn chime on/off, specify additional cons and run an LCD display test. I'm stuck in that mode now. I can't get back to "Ready To Arm". Is there a way out of this ? It's almost like the system doesn't like the keypads having different addresses !
If you are getting a blank display after setting the addresses, then it is not a pro3000. After you held 1&3, entered 16, did you press star a couple times?
Go back to the panel. at the bottom of the schematic on the door, centered and in bold, what does it say?
IJ
IJ
I'm beginning to think that he's got a different model panel, possibly mounted in the system can for a SW-3000 (not uncommon when people have problems with the ADT version of Ademco panels). What is on the _circuit board_?
why don't we do this disconnect all keypads except the alpha addressed as 16 power down then back up * through the voice chime, additional console until it's at the normal screen. It may not say ready to arm but try to get it to the point it says ready or not ready to arm
The original Safewatch Pro 2000 system is a clone of a Vista 20se system, which has a completely different program map. It does, however use the same keypads (most relatively recent Ademco panels use the same series of keypads). There also may be an older Safewatch Pro that is a Vista 20 (without the "se").
In either case, the keypads will be set to non addressable mode (31), _all_ of the previous versions, however, enter programming with [install code] + 8 + 00.
Somewhere on the PC board will be a part number, either on the main chip, or in lettering on the edge of the PC board that will likely have the word vista or via probably with an A or ADT at the end of the string.
#21
Originally Posted by Michael90
I had the same thought. Measuring the board will tell us if it's a 2000 or 3000.
#22
A-Ha! Mystery solved. You actually have an ADT version of a Vista 10 (probably se) system, which do, in fact, enter program mode with [install code] + 8 + 0. I suspect that you had a motherboard replacement for the original SW 3000 unit, and they picked a board that would fit the can (although those ademco cans will hold pretty much any board they make, the installer may have elected to not move the brackets).
Assuming no drastic changes in the ADT version:
The keypads should be in non-addressable mode (31)
The correct key sequence for changing the master code should be:
[install code] + 8 + 2 + [new master code]
This system will only hold a total of 4 user codes beyond the master.
#25
I've got a control panel with 10ADTEG printed on it and one 6128 or it may be a 6127 keypad, but it's definitly not an Alpha Keypad. Anyway, it was working just fine, it would go to green Ready and I tested each zone and they all displayed property when a door or window was open. I just couldn't arm it becuase I didn't know the installer code or the master code. ( kept trying 4110 and 4111 before reading this post and neither one worked)
I have it soley running off of battery power because the power adapter is missing... don't ask... its was a foreclosure.
I powered it down and on via battery only (cause I don't know where to find a replacement A/C adapter yet), got the d1 on the display, did the # + * then typed *20 and got EE pause EE pause EE and so on...
So then I held down the 1 + 3. got a beep. typed 16* and the display went blank. The keypad still lights up, but nothing on the display.
Then I powered the control panel down and back on, now both the green Ready and red Armed lamp turn on for about 50 seconds but the display is completely blank and I don't know how to get back where I started to even try that default ADT installer code.
After ready this tread, I'm thinking I should bought an 6150 or 6160 Alpha Keypad before starting all of this.
What's your best guess?
If I buy an Alpha Keypad will it display something so I can get out of this 1 + 3 mode thing?
Or, could the EEProm be damaged and I just need to get a new control panel?
#26
Get a replacement transformer, they really don't cost much and aren't hard to find. 16vac 30-40VA will do the trick.
Change the keypad address back to 31, it's another Vista 10se clone:
Here's the installer manual: http://ibsalbany.com/Burglar%20Alarm...ISTA10SEii.pdf
#27
Ok, thanks.
My keypad is stuck in addressing mode, when I try to type in 3 to change the address from 16 to 31, it doesn't register the number 3.
I looked over the Vista 10SEpdf that you posted. It doesn't have any instructions on setting the keypad address. it just says 'Refer to the instructions provided with the keypad for address setting procedure.'
Well I just did a search for the Keypad instructions for a 6128 and found them on another thread:
http://forum.doityourself.com/electr...10-keypad.html
Honestly I don't know if I even have a 6127(non-addressable) or a 6128(addressable). At this point I'm assuming that because 1 & 3 got me to a blank display that it's a 6128(addressable). Anyway I'll try going through the KeyPad Instructions for the 6128 tonight.
#28
well, I followed the keypad address programming instructions for the 6128 and got it back to Ready.
Tried that default ADT installer code and it worked!!!!
I'm so happy this has saved me hundreds of dollars by avoiding putting in a new unit.
Now if only I had been this determined to get this working as soon as I moved in I might have saved myself at least 2 thousand dollars worth of computer equipment that was stolen just last month... oh well.
Thanks for help!
Thanks for help!
#29
Thanks ! I got a copy of the installation manual. It explained all of the codes. Now, I have another problem. I'm able to reset the installer code. However, I can't seem to change the master code with the installer code. The previous house owner gave me the code that he used to arm/disarm it. I'm guessing that the one he gave me is NOT the master code because I can't seem to use that one to change the code either. How do I use the installer code to change the master code ? I tried:
#30
If you look at the list of "ADT" models in the sticky titled "Alarm Forum FAQ: Please read before posting", you will see that a Safewatch 3000 is a modified version of the Vista 20p.
Websearch using the phrase "Vista 20p installer manual". The pdf of the manual will be in the first 3-4 results.
