How do I enable Paging mode with a Safewatch Pro 2000?
Old 05-27-05, 08:13 AM
madddogg
I would like to know how to configure the paging mode with a Safewatch Pro 2000?
Does ADT disable the panel if service is cancelled?
Thanks
Madd Dogg!
Old 05-27-05, 08:58 AM
Sharp Advice's Avatar
Admin Emeritus
Received 5 Votes on 4 Posts
Hello: Madd Dogg. Welcome to the Do It Yourself Web Site.
I did a search within this forum topic on that brand and model.
This is what that search produced:
http://forum.doityourself.com/search.php?searchid=46327
Reading the already existing questions and replies posted, may provide the help needed.
Check back on your question several more times. Other members posting replies in this forum topic may offer you additional advice, suggestions and or help needed.
Kindly use the reply button to post all replies, add additional information or ask additional questions when replies are posted. Using this method moves the topic back up to the top of the list of questions automatically.
Helping Out Here Too.
Web Site Host, Forums Monitor & Multiple Topics Moderator.
Personal Reminder:
Buckle Up & Drive Safely.
"The Life You Save, May Be Your Own."
Old 05-27-05, 06:25 PM
I have never tried it without primary going to a receiver but try this:
go into programming then press *41*
then * 42 your pager number
then * 43 put in any 4 digits for an acct number(will be 1st 4 digits on pager)
then *49 press 6
then *99
try sending an alarm or duress see if it comes to your pager then wait approx 30 minutes and check keypad and see if there is a fc showing
you may also while in programming go to *94 then * then *95 0 then *99
what we did: *41* erased primary phone num. 42 pager num. 49 told it to send alarms troubles and opens for users 5 and up 94 we stopped it from calling for computerloads 95 stopped it from answering a computer calling it
this would be an example of pager display for an alarm on zone 2
911-----0002
alarm zone number
if it doesnt work post again so we can put it back to the way it was
