Ademco Vista 20-P and Smoke Detectors
Old 05-29-05, 11:51 AM
JoeHack
What Smoke Detectorts are compatible with the Ademco Vista 20-P. I see alot out there that have 50P or higher. I just want one that is 2 or 4 wire and will work with my Ademco Vista 20-P.
Old 05-29-05, 06:35 PM
Any 2 or 4 wire 12volt smoke will work. When you see a smoke detector compatiblity chart those are the smokes that when ul approved the panel those are the ones they used. So if you are going for a ul system for insurance puposes use one that is listed for this panel. Otherwise its your choice. I wont recommend a certain brand but try to get one from a well known manufactor
Old 05-29-05, 06:40 PM
JoeHack
Thanks for the Reply
I will look for a ul and 12volt from Ademco. Didn't want to get one and have to return it over and over again until I found one that worked.
Thanks Again
Old 05-29-05, 06:43 PM
I believe the ones they list are from system sensor. The 2 wires are a little more install friendly
Old 05-30-05, 02:29 PM
Integratedj
System sensor smokes are all my company will use anymore.
If you use 2 wire smokes, they must go on zone 1 of the board, + on terminal 8, - on terminal 9.
If you use 4 wire smokes, they can go anywhere, including on zone expanders.
IJ
