Cannot reset DSC pc1555
Old 06-02-05, 07:39 PM
joeboatertx
Hi all,
I am trying to reset a dsc pc1555 (Power 632) back to factory defaults. I have tried power-up with a jumper between p1 and z1 with no luck. I only have ac power connected besides the p1-z1 jumper when I power up. It powers up in an armed state and will eventually go into alarm so it appears to be working but I do not remember the disarm code or how it was programmed. Any suggestions?
Old 06-03-05, 03:59 PM
Received 139 Votes on 128 Posts
When you power the panel up, do you hear a series of clicks (about 10)? If so, then the "installer lockout" feature was used, and short of a dumb luck guess at the installer code, there is no back door way to gain control of this panel.
Old 06-09-05, 06:43 PM
joeboatertx
Panel reset
There must be some way to do it. How do these companies charging for the reset do it?
Old 06-10-05, 04:38 AM
It requires specific software that is not commonly available, even to most installers. Some of them simply replace the eeprom.
