Car alarm stopped working
Old 06-07-05, 05:48 AM
deb789
I have a car alarm on my car and it stopped the making the beeping noise. Ive replaced the car battery on my car and still the car alarm is not working.My led light on the inside of the rear inside car the red led light does not show red.Ive changed the battery on my remotes .The led lights show on the remotes but still no luck on the car alarm. I do not have the make of this alarm cause it was done in a auto car alarm shop. Please help!!
Old 06-07-05, 11:47 AM
D
First, check the fuses at
the fusebox, then look carefully under the dash, look for more fuses-either in the wiring or at the alarm box itself.
Is there anything else in the car not working, such as the dome light, radio memory, cigaratte lighter? These are common places to tap into for power to the alarm system. Check these fuses closely as well.
If none of the above work, maybe take it back to the shop that installed it and see if they can fix it?
If not, then look on the back of your keychain- hopefully there will be a model # or FCC ID that can be used to figure out who made the alarm system: http://www.fcc.gov/oet/fccid/help.html
