Glass Breakage Sensor
Old 06-13-05, 06:52 AM
I have a Radio Shack Plug'N Power home alarm systme and I want to ad a glass breakage sensor to it. The wireless window transmitters have contacts to plug in additinoal sensors with 2 contacts. The glass breakage sensors I have seen require 4 wires contacts. Are there any that will work with this system?
Thank,
Scott
Old 06-13-05, 02:47 PM
Received 139 Votes on 128 Posts
You would have to get devices that are compatable with that wireless setup, which means dealing with RS. There are virtually no aftermarket wireless devices.
Old 06-14-05, 04:08 AM
Hard WIred Sensors
I understand that I cannot get a aftermarket wireless sensors for this alarm. I am interested in hardwired sensors that will work.
Scott
Old 06-14-05, 04:38 AM
For the hardwired motions to work, you have to get 12v power to them. If the control panel doesn't have a means to provide this, then you are stuck using wireless only. I'm not familier with these RS models, so I don't know what outputs and inputs they provide. Other than certain brand specific adressable models, there's no such thing as a 2-wire motion detector.
Old 06-14-05, 04:45 AM
Do you know of any 2 wire glass breakage sensors or smoke/carbon monoxide?
Old 06-14-05, 06:35 PM
There are the "window bug" devices that stick to a window, but there is a limit to how many can be on a single circuit (like 6-10). Those are purely mechanical. Otherwise, it's the same deal, no 12vdc, no active devices. 2 wire smokes are widely available, but must be connected to the hardwired input zone of an alarm panel that supports such devices.
Old 06-15-05, 04:24 AM
Thanks you for you help.
