All Zones Light Up For No Reason on DSC PC1555 (New Install)
Old 06-26-05, 06:44 PM
nguyent888
Unhappy All Zones Light Up For No Reason on DSC PC1555 (New Install)
Hi,
I just installed a new DSC PC 1555. When I power up the system, zones 1 through 6 light up and won't shut off. This unit replaces an older system which was working except I needed to add additional zones. No trouble is reported and all system tests come back normal. I have checked my connections and everything looks as it should. I have tried doing a factory reset, and even eliminating all zones except one to see if a bad sensor was causing problems and still nothing!
Also, I have gone through the installers manual and found no mention of this problem.
Please help! Any suggestions?
Old 06-26-05, 08:09 PM
Received 314 Upvotes on 289 Posts
You either need to put the resistors on each loop, or go into programming section 013 and turn on option 1 (which removes the requirement for the resistors).
Old 06-27-05, 10:48 PM
nguyent888
How??
Could someone please explain how I would go about activating option 13 to "on" thanks,
Old 06-28-05, 04:33 AM
Go into programming, go to section 13, press number key 1, the first led (or LCD digit) will turn on. Press # to enter the change. Keep pressing # to exit programming. Alternately, install the resistors.
Read over the first part of the manual's section on how to program. DSC programming is not intuitive, but the information's there.
Old 07-05-05, 05:05 PM
gadgetdog
did you set the system to normally closed loops?
It is under [013]
Old 07-05-05, 09:13 PM
nguyent888
Problem solved
Thanks for your help everyone, problem is solved
