First Alert Fa110c/fa120c Service/programming Manual Needed
Old 06-28-05, 11:09 AM
HASSETANDS
I Am A D.Y.I. Homeowner And Need To Find A Service/programming/installation Manual For A Fa120c Security Alarm. I Want To Change The Entry/exit Delay Times, I Know How To Get Into The Program Mode But Do Not Have The Explaintion For Each Code. I Am Also Getting A Not Ready Error On Zones #05-06, Does This Have To Do With An Optional Fire Alarm (nothing Installed On These Zones)?
T. Hasse
Old 06-29-05, 04:33 AM
Received 265 Upvotes on 244 Posts
This panel is basically the same as an Ademco 4110xm model. That's the one you should search for a manual under (actual First Alert installer manuals are hard to come by).
If there are no devices attached to those zones, then you need to either put 2k resistors on the unused zones, or disable them in programming.
Old 06-30-05, 07:53 PM
HASSETANDS
First alert fa110c
Thanks MrRonFL, I tried to program from a vista 20 manual at first which caused zone 5 & 6 to be turned on. After I found the Ademco 4110xl manual I corrected the problem and found the exit delay code.
