DSC 1550, 4 phone connections, 2 Wires ?
Hi, On my DSC 1550 there are 4 connection points for the phone line out, these are named R1, T1, RNG, and TIP, my outbound phone line has two wires + and -ve.......how should this be connected, ?
Also if the phone line is removed there is no trouble light on the panel to indicate this change......does that mean the autodialling part of the board has a problem.
Thanks for any help
JW Cape Town, SA.
Thanks for any help
JW Cape Town, SA.
Hmmm, based on the assumption that your S. African telco is like North America (loop start), the +VE will be the equal to Ring, and the -VE will be tip. You bring your line in from the telco on Ring and Tip and return it to your house phones via R1 and T1.
The line monitoring feature has to be enabled in the system programming, and the program has to be set to have a keypad sounder on loss of telco.
If your phone system is radically different (ground start, or the like) then things get a bit more complex...
Oops, my error. That model doesn't have a phone line monitor feature. The only way to protect the phone line for that model is to use the "trap" feature on the RJ-31X jack.
It's a pretty basic panel.
