report code question
Old 07-11-05, 06:25 PM
JGL97
I'm programming 5816 transmitters for the first time not sure what the report codes mean or what to set them for. I'm using the 5816 transmitters for window contacts.
Thanks
Old 07-11-05, 07:58 PM
Received 314 Upvotes on 289 Posts
What they are set for depends on the format that the system is communicating with. If you are setting up a local only system, it doesn't matter. If you are setting up pager format or 4+2 format each report code needs to be a unique 2 digit number, for Contact ID, you only need to plug any number into the first digit to set the pre programmed codes.
