for fire alarm
for fire alarm
i just own the house.
previous owner has left security systerm there with everything been hooked up but not activated.
its called safco security. looks local company in san jose, california and i'm in east bay california.
now i don't have any code to check.......is there a way.....
also, if this thing helps for fire protection like while i'm out and fire gets it and dials to fire department would it do this thing?
i'm basically look for this reason to use.
i'm totally new here and don't know much so bear with me and previous owner couldn't be able to meet at all nor real state agent let us know.
would greatly appreciate.
thanks
thanks
Safeco is a dealer. We need to know the maker of the hardware to hazard a guess at what it can and can't do. Most of the major alarm brands support smoke detectors in one form or another.
To find the brand you need to look inside control cabinet where the backup battery is.
What that tells me is that it has a wireless reciever. The model number will be either on a diagram on the inside of the system can door, or on one of the main IC chips it will be [PC xxxxx]. More than likely its either a 1555 (Power 632), a 5010 (Power 832), or a 5020 (power 864). There are a couple of others, but those are the three most common.
Powerseries 433 is what i see in the front.
there's nothing underneath the door.
but behind the IC chip i can see
LCD5501Z32-433
this is the label i can see at the back of chip.
does it help.
thanks a lot.
LCD5501Z32-433
does it help.
thanks a lot.
You are looking at the _keypad_ not the control unit. The _control_ is a (usually) beige metal box about 16" square located most likely in the master bedroom closet, or a similar location.
However your keypad is also the wireless reciever for the alarm system.
Other important information
You may want to contact the dealer. The system may still be conntected to your phone line. If the system goes off for any reason and the authorities are dispatched, you may get a false alarm fine. Check with the local authorities about alarm permits. Sometimes the dealer will service their own system and reprogram an existing system if you sign up for monitoring.
