Pc1555 Trouble Lite 1
Old 07-22-05, 05:10 AM
DMARR35
I have a PC1555 I have trouble lite 1. My manual says call service installer but that is me can you help me? Thank You
Old 07-22-05, 02:11 PM
Pc1555
First I would need to know what happened recently. Did you have an alarm, power outage, or phone service interruption? First enter in your code like you would do when you disarm, do this twice. Then arm your system, and then disarm your system. This should clear all alarms and signals in memory. Contact your monitoring service and find out what signals are coming in. If none of those has happened, it is likely a low system battery. To replace your battery, there should be a grey, or beige control panel in a closet somewhere in the house. Likely in the master bedroom closet. Open the control panel, unplug the battery and replace. It should be a 12V 4aH sealed lead acid battery. You should be able to find them at Radio Shack.
Old 07-23-05, 05:16 AM
DMARR35
I tryed setting the system as you said but it still shows problem.I wil replace battery anyway but there is a trouble code for battery.
