Programming an ADT Safewatch Pro 3000
Old 07-26-05, 02:41 PM
tknick
I have an ADT Safewatch Pro 3000 alarm which I have gathered from these forums is an Ademco Vista 20P series alarm. I was able to download the installers manual and have read several threads about retreiving the installer code on ADT alarms. The question I have is while reviewing the installation manual, it states "You must have a 2-line Alpha display keypad".
My keypad has 2 digit display (to display faults and open circuits). Everything else has it's own place on the display and is either on or off (Away, Stay, NO AC, etc).
Is this a 2-line Alpha display or is it not possible to reprogram the system with the keypad I have?
Thanks in advance for the help.
Travis
Old 07-26-05, 06:12 PM
Received 265 Upvotes on 244 Posts
The keypad is a "fixed alpha" keypad. It will do for _some_ of the basic programming, but unless you are very patient, and/or have a good memory, it's _very_ difficult to program the zones, outputs and other such things without the 2-line keypad.
Old 07-26-05, 07:04 PM
tknick
Thanks for the quick reply! What I would like to do is program one of the bottom two buttons on the left side of the control pad for "stay" so I don't have to enter the code. The top one is preprogrammed for police and the second for fire. Is that possible with the panel I've got?
Thanks
Travis
Old 07-27-05, 07:34 PM
As Ron said, it's a whole heck of lot easier with an alpha keypad. Enter programming, then enter *57. It will ask you to press the button you want to use. Next it will ask for the partition you want to use (usually "1"). Then it will ask the function you want for that button. Enter "04" (arm-stay). Then get back out of programming (*99).
Old 07-28-05, 06:59 AM
jdeanth
You could also turn on quick arming field 21 in programming. This allows you to use the # key then the arming mode.
Old 07-28-05, 12:27 PM
tknick
Thanks Guys! You guys are the best. I didn't even know about the quick arming mode. That sounds exactly like what I wanted to do anyway.
Thanks again for the great quick help!
Travis
