Installer code question
Old 08-06-05, 04:33 PM
A
Hi,
I'm trying to add a wireless keypad to an working vista 15P system.
I already know how to install the keypad but, in order to do that I
need to get the installer code to change the house ID. I don't know the
installer code and one way of getting into programming mode is
to use Installer Code + 800 and usually the installer code is the
model of the central control panel (i'm guessing).
1. I don't know what the model number is. Is there a way to find it
out or where it will be located on the panel?
2. If I cannot get installer code, I can powerdown the whole system
and use *+# within 30 seconds to get into programming mode.
Now, if I power down the whole system, will I be losing all the
zone assignments?. Do I have to start from scratch?
3. ADT is currently monitoring the system so, i'm going to call
them to put the system in "Test" mode while I do this. When I
power down will it cause any false alarm at ADT?
Thank you for all the help.
Ansari
Old 08-06-05, 10:37 PM
Received 265 Upvotes on 244 Posts
Originally Posted by ansarim
Hi,
A: The default for the 15/20p models is 4112. If you have an ADT installed system, the code is probably 6321.
A: No. The data is in an eeprom. The data stays unless you change it.
A: The panel might send a low battery signal, but that's about it.
Ansari
You shouldn't have too much trouble on this. If the system already has wireless, then adding your wireless keypad shouldn't be a big deal.
Old 08-07-05, 03:04 PM
A
Thanks!!
Thanks a lot.
I installed the keypad without any issues and the installer code 6321
turned out to be the correct one.
Thanks again.
Ansari
