Help with Napco Gemini GEM-p816 and RP3Dgtl pad
I just bought the house and the previous owner use to have contract with Slomins. I didn't renew the contract with them. I would like to use it without Slomins. I need the Master Security code to get to the programing mode. I look at the p816 and there is a 6 digits number, I tried that 6 digits + Function key and didn't work (just beep 4 times)
Anyone know the master code for this system?
Thanks
Kenny
Thanks
Kenny
The default dealer code for these systems is 456789. If they changed it from that, then you are stuck, because you have to access dealer programming to change the user code.
From a readover of the installer and programming manuals (thee is one of each), there doesn't seem to be a hardware default.
