Safewatch Pro 2000 No phone line, No monitoring
Old 10-02-05, 10:46 AM
yoabear
Question Safewatch Pro 2000 No phone line, No monitoring
I have disconnected the phone line to my house, and I have dropped ADT.
My alarm, the safewatch pro 2000 worked for a short period and then will not arm saying not ready with an error code FC. I understand that this is Communication Failure, but how do I by pass it?
Thanks Jason
Old 10-02-05, 11:10 AM
Received 89 Votes on 83 Posts
Ok, first you will need to get into programming: For this system, it should be 6321 + 8 + 00. It should come up in program mode. Next, enter *41*, *42*, *43*, *44*, and *94*. This will erase all account and phone numbers programmed into the panel (no, it will not affect your user codes), and make it a local system that ADT cannot dial into remotely. Finally, enter *99. This will exit program mode and go back to run mode.
That should do the trick.
Old 10-02-05, 11:29 AM
yoabear
Amazing
u da man!
Thanks you very much that worked perfectly.
Jason
