DSC PC1565-programing...
Hi... I have alarm pc 1565 and I have problem with manual programing communicator dialing. All zones are programed but when I'm trying to program alarm to activate my cell phone I have problems. I was using functions 310 and 311 for instaling phone numbers, also function 380 and 160 and 360. Function 320 and 361 are not quite clear to me. I am asking for help if someone can explane to me on example complete procedure for manual programing so that can finaly work.Also, after my programing of complete system phone conection was lost and after disarming the system conection was not returned and therefore I have question is there on the keyboard some opcion to restore the phone conection...Thank you in advance!
Hookay:
Sections 310 and 311 are for the account numbers normally used by a standard central station monitoring reciever, and for the pager to identify the fact that it's coming from the alarm (many people using pager format program their house number or 0911 into this space)
Sections 301, 302, and 303 are where actual phone numbers go.
Section 380 is where the dialer and it's various functions are turned on and off.
Section 160 is where you set how many times the dialer tries before it gives up.
Section 360 is where the format is selected. Phone number 2 (programmed in section 302) is factory defaulted to be a pager dial out, but you can set the first one to do so if it's easier, or even have multiple pager outputs (up to 3; whatever the first (301) phone is set to do, the third (303) also does).
Sections 361-368 are where you tell the panel which activity should be reported to which phone number. Phone number one is active by default
Section 320 is where you program in the 2 digit numbers that will appear on the pager display. You can use any number except a hexadecimal C. This allows you to determine which zone or trouble condition is generating the page.
From the manual:
From the manual:
The panel will attempt to call the pager once. Once the appropriate
telephone number is dialed, the panel will send the
account number and Reporting Code followed by the [#] key
(Hex [C]).
The panel has no way of confirming if the pager was called
successfully. A Failure To Communicate trouble will only be
generated if the panel detects a busy tone on all dialing
attempts, or if no dial tone is detected on all dialing attempts.
The pager format will not cause any form of ringback.
(Hex [C]).
