ADT (Moose) a910 programming question
Old 11-21-05, 04:32 PM
scott100
I have deleted the master code from location 1. How can I restore the keypad to functionality?
Thanks.
Old 11-21-05, 06:13 PM
You can bootstrap the system into program mode, and fix the problem from there. There is a default for the master code; on a standard Moose Z900 it's in program location 250, but I know that the ADT version has a different memory map. This thread recently discussed the same panel.
Old 11-21-05, 07:33 PM
scott100
I powered down and up, then pressed 9+3. After a short time all lights began blinking. But I am unsure what sequence of numbers, etc. to press after that.
Thanks.
Old 11-21-05, 09:17 PM
Sorry, I thought you would realize that you needed the installer manual to do this. On a Z900, the panel this is based on, once you enter program mode with 3 + 9, you enter 250 # which defaults the installer code to 1245.
I'm not sure that it's the same for a ADT modified unit. I'm hoping that the person from the referenced thread can verify from his copy of the memory map, what the correct address is.
I hope this clarifies things.
