How to reset date/clock DSC Power 832???
It's been a couple of years since i installed this DSC 832 panel and now i had to power it down to trace a problem but now i can not remember how to reset the clock. I have the programing manual and the instalation manual, but i can not find the procedure in either one.
Any help would be appreciated.
Thanks; Mike.
Thanks; Mike.
In the installer manual it's in the section on *6 user functions (around page 16).
In the User Manual it's at the top of page 13:
Setting the System Date and Time
To set the system time, enter[*] [6] followed by the Master Code. Press [1]. The keypad will now accept 10 consecutive digits:
• Enter the Time in Hours and Minutes using the 24 Hour format (00:00 to 23:59).
• Enter the Date in Months, Days and Years (MM DD YY).
NOTE: If you have an LCD keypad, your installer may have programmed your system to display the time and date while the keypad is idle. If this is the case, you may have to press the [#] key to clear the date and time before entering an access code to arm the system, or before performing any
other keypad function.
thanks, that did the trick. yes i do have an lcd display.
unfortunatly there is another problem with the panel i believe. maybe you can help see this post:
http://forum.doityourself.com/showthread.php?t=243343
thanks again.
thanks again.
