dsc 5010 programming help needed
I'm a newbie to the security system world so forgive me if my questions seem stupid, I have two to start with
1- exactly how do I turn off the need for zone reisistors, I'm running one motion detector and two door/window contacts, all are normally closed
2- how do I turn off the TLM option? I wont be hooking it to a phone line for the time being and its showing as an error after hitting *2
I bought a used system that was defaulted and I printed out the manual, but its not very descriptive at all
Thanks
Don
Thanks
Don
There have been a recent rash of DSC power series panel questions just like this. The questions you have have been answered in a number of recent threads. Just read through them, and if you are still confused, let us know.
DSC manuals (and most alarm manuals) are not written like a set of stereo set up instructions. They are rough guidelines because there is such variation in how these things can be setup. Read through the manual, especially the section on how to program, but realize that it's not a step-by-step type of manual. There is a lot of page flipping involved.
If you didn't also get the programming guide, (it's a seperate booklet) you will need that, because without it, the instructions in the manual make even less sense.
actually to be honest that is why I am writing for help I did scan through all the info I could find on this topic and then had to sign up on here just to post a thread for help, I don't have the programming guide as you mentioned obviously that is why I am even more confused haha
I was hoping someone could tell me how to program the two things I asked about, the rest I have read through what I have and I'm sure I can figure it out (ie, codes, zone bypassing etc)
Thanks
Don
Thanks
Don
You will need that guide. Even with a blind walkthrough, you need the reference. DSC doesn't make it clear, but their installer manual for this system is two parts, the instructions and the program sheets.
If you want a blind disable for TLM and zone resistors, key the following:
* + 8 + [installer code]
press 013
press 1
press #
press 015
press 7
press 1
press #
press 380
press 1
press # twice
Those keystrokes turn off zone resistors, TLM, and the dialer, in that order.
press 013
press 1
press #
press 015
press 7
press 1
press #
press 380
press 1
press # twice
Hey Ron
everything is working fine but I do have another question, when I arm the system it takes forever to actually set itself up and when I open the door the siren goes off instantly, how do I set the delay times? say 30 seconds in and out would be just fine
Z1 is a motion detector
Z2 is the door
Z3 is the window
this is just my garage hiding my drag bike and ski doo from the rest of the world
Thanks
Don
Z2 is the door
Z3 is the window
Thanks
Don
In that case, you may have entered the door improperly (you did set the zone types for the zones?).
The correct zone type for an entry-exit door is 03. The default setting for zone 2 is interior. Your easiest fix is to switch zone 1 and 2. That way the default settings will match what you are using the zones for, and you don't have to learn anymore programming.
Try this then:
press * + 8 + [installer code]
press 001
press 01 04 03 00 00 00 00 00
press 005
press 030 045 030 005
press # until you are back in run mode.
Remember, the leading zeros are needed.
press 001
press 005
Hmm. Try this, go into program, go to 005, and press one of the panic keys (you have to press both halves of the key at the same time)
Listen to the keypad. Count how many beeps accompany each keypress. Each time you go from one entry section to another it will beep twice instead of once. There were a couple versions of this panel that used 2 digit entrys in some of the timer entrys instead of 3 digits. The entry delays are the first two groups.
No, for this purpose the panic key is only a stepper switch.
You didn't say what keypad you had, but by stepping through the section, and noting which LEDs on the keypad are lit at which step, you can read the the section and verify that the times are correctly programmed.
Seriously, read the instructions at the start of the manual's section on how to program. The readout is in hexadecimal, and it has to be translated to mean anything.
One of three things is going on: You either have the wrong time programmed in for the exit time; the zone's are misconfigured, or you have the door you are opening wired to the wrong zone input. Really, those are the only places to look.
Ron,
when I put the codes in and tested it the system set off the alarm like I told you, five minutes ago I went to the garage to get something and the system actually gave me time to punch in the key,
not sure why it didnt work the first time but hey, I'm not complaining
I really appreciate all your help, you've been a saint
thanks for all your time
I hope you and your family have a merry Christmas
Don
Don
Hello all,
I was wondering if it is possible to arm one zone and not the anothers on these alarms, I want to expand my system to protect my home and garage, they are not attached, so I'd like to be able to arm the garage while I am in the house or have them both armed when I am gone away
thanks in advance
Don :mask:
thanks in advance
Don :mask:
Two choices. Add the zones into the system as normal, then bypass them when you arm the system (there is a way to program a "group bypass"), or partition the system and have those zones be a virtual second system.
Each technique has it's plusses and minuses.
Section 5.9 partition/zone assignment gives you the info on partitioning.
I was mistaken on the group bypass. I mixed it up with a similar system from another maker. You either use the manual bypass command, or you can program the bypass command to a function key.
