Solar Powered Security Light
Old 02-08-06, 09:10 AM
A
I'm toying with the idea of putting an outside light up but I really dont want the hassle of running mains outside. I have found some 'solar powered' security lights with PIR sensors. Has anyone used these? It looks like the solar panel charges up a lead acid battery, but I just wonder if it can provide enough juice. The panel looks like it is about A5 sized and the bulb is a 10Watt Halogen
Old 02-08-06, 11:16 AM
Received 261 Upvotes on 240 Posts
Those solars have become pretty main stream. Those same battery sizes are used to run emergency lights for commercial buildings, and a 10W halogen lamp puts out a surprising amount of light. Since it's motion sensor, and the light is only on as needed, it may well turn the trick for you.
Old 02-09-06, 10:07 AM
A
lights
I only need a small light to be able to see a gate to unlock and then park my bike. I reckon it should be enough? The area is miles away from the mains and I dont really fancy running long cables!
