DSC 1555 Pager Alarm Codes
Old 03-24-06, 01:15 PM
D
Using the help from the web I have set up my DSC 1555 to dial my cell phone if there is an alarm. I just got a call from my home while I was there and there was no alarm. I didn't take the time to set up the proper delays so it will send the alarm code. I have corrected that and just done a system test and received a text message with the alarm code 0976, now I need to find something to decipher the codes I am getting. I assume that is just the system test code. But I need to know how to decipher it if I get a call while at work I will know what kind of alarm is triggered before calling the cops and racing home to find out I forgot to bypass the motion sensor and the cat triggered the alarm.
Was also wondering if there was a way I could disable the audible siren to make it a silent alarm? Got a psycho ex and if she tries to break in would be nice if she was still there when the cops show up.
Thanks..
Dave
Old 03-24-06, 06:10 PM
Received 265 Upvotes on 244 Posts
Basically, it sends whatever codes are programmed into the panel:
The panel will transmit the 2-digit reporting code programmed. There are no special
requirements, any 2-digit number can be programmed for any event. A simple pattern should be
used (i.e. code [21] for opening by user 1, [22] for user 2 etc…).
Program the reporting codes required in Section [320] to [353].
