Vista-15p - How do I reset the code?
Old 04-06-06, 07:15 PM
K
I recently purchased a house with a ademco Vista-15p system already installed. I want to use the system without signing up for the monitoring. How do I reset the code? How do I program it to work without monitoring?
I appreciate any help!
Kim Olstroem
Old 04-06-06, 08:19 PM
D
check this link to a previous post relating to the installation code, the manual for the vista 20p includes the 15p as well.
goto: Alarm Forum FAQ (See Retrieving Code) in this article
http://forum.doityourself.com/showth...all+code+vista
and if you need an install manual you can check this link,
http://www.homesecuritystore.com/protect_ademco.html
I think the code for the Vista 15P should be 6321 if it hasn't been changed. The first link will explain the proceedure to get into the programming mode.
hope this helps
Old 04-07-06, 03:34 PM
Received 265 Upvotes on 244 Posts
It will only be 6321 if the system was installed/monitored by ADT. Once you have an installer code, we can walk you through disabling the dialer, and setting a new master user code.
