DSC Power Series 433 Master Reset, Bought a house with
Old 05-10-06, 05:13 PM
A
DSC Power Series 433 Master Reset, Bought a house with @ prior owner does not remember Master Code (Manual Indicates DSC Power Series/Envoy LCD).
From the Companies Web Site the LCD Panel looks like the 5501.
I called the DSC from work and them seemed like they would help but when I get home DSC closed (they wanted to walk me through in front of it).
In the meantime is their a way to reset the master password without nuking the settings too.? The unit is in Ready mode and does announce/beeb when opening doors. The House is from 2004. The Manual has 2003 copyright. I found essentially the same manual on line as a PDF with a 2005 date.
Thanx
Old 05-10-06, 05:40 PM
A
The only way to reset the master code. Is with the existing master code or the installer code. Only other way is to default the panel to factory.
Old 05-10-06, 05:45 PM
Received 265 Upvotes on 244 Posts
Are you sure about that model? Could it be Power 432?
(The actual model number will be PC580)
In any case: If the default installer code [0580] has never been changed, you can change the master code from the programming level. If not, the only other recourse is a hardware default, short of a lucky guess at the correct code.
