Fire Sensor - 135 degrees needed
Old 05-28-06, 07:15 PM
n1ml's Avatar
We have both smoke and fire sensors in our home. The fire sensors tie into the central station. One of the fire sensors failed. It appears to have a small dent in it. They are about 1 1/2" in diameter and have two double screw terminals on the back. The unit is about 1" thick. They are normally open and close on 135 degrees heat. I need to find a source for these for replacement. They are 30 years old and now I do not trust them after the alarm today. It was lucky we were home so we did not bother the fire dept. Lucky. Anyone know a source for the devices?
Thanks
Old 05-29-06, 02:47 PM
That is an older design. I think that Edwards still makes those "hockey puck" style heat detectors, but most people are replacing them with the slightly larger Rate of Rise heat detectors.
Old 05-30-06, 04:14 PM
n1ml's Avatar
Any suggestions where I can get them? I need 11 units.
Thanks
Old 05-30-06, 05:28 PM
If there is a local fire alarm installation company, they may sell them to you over the counter. Otherwise, online search using the phrase "rate of rise heat detector".
I picked one hit at random; try this for an example.
Old 05-31-06, 04:00 PM
n1ml's Avatar
Do you suggest a 135 degree heat detector or a combo unit? I also see 135 fixed and rate of rise. We have the old style throughout the house making up 3 fire zones that tie to the central station. We have them in the basement near the heating unit, in the garage, kitchen, halls and in all bedrooms. Is a mix of types preferred?
Old 05-31-06, 04:09 PM
The rate of rise + fixed is the better design, as it will react to the rapid increase in temp for an incipient fire better, and will catch a fire when it is smaller (in general).
Remember, these things are not _life safety_ devices; they shouldn't be used where a smoke detector is a better choice.
Old 06-01-06, 08:47 AM
n1ml's Avatar
We have 11 temp sensors and 11 smokes in the house (also have 3 COs by MA law. The smokes are inter-connected but do not go to the central station. I plan to the dual fixed and rate of rise as replacements. Thanks for your advice.
