LYNX-R Problem
Old 06-01-06, 02:30 PM
LYNX-R Problem
Hello,
I recently purchased a house with the ADEMCO LYNX-R installed.
I accidently armed the system and cannot disarm or re-set it. The code was forgotten by the previous owner since he never used it and there was no external monitoring.
What do I do to get a useable code to turn it "off"?
Thanks,
Jimger
Old 06-01-06, 06:13 PM
Received 25 Votes on 24 Posts
First unplug the backup battery pack, then unplug the ac power transformer. Wait a few moments, plug the AC power back in.
Within 50 seconds, press * + # at the same time. This should kick the unit into program mode.
Press #20 -- The panel will display the installer code one digit at a time. You will need this code to change the master code.
Exit program mode by entering *99; it should no longer be armed.
Reconnect the battery.
In run mode, enter Installer Code + 8 + 02 + (new)4-digit Master Code.
Test your code by trying to turn on and off the chime function.
Old 06-04-06, 07:04 PM
Angry Lynxr
Thanks for the info, but it did not work. I guess the panel is beyond repair unless you have another idea.
Sincerely,
Jimger
Old 06-05-06, 04:18 PM
Make sure you are disconnecting both battery and AC power before you try the bootstrap. The final gambit you can try is holding down * + # while power is applied. This bypasses the lockout on many Honeywell/Ademco systems.
