5010 LED ON after program
Old 06-03-06, 12:19 PM
Angry 5010 LED ON after program
Hi,
I have reset the panel to default and programmed as the follow instructions "from a thread".
After the program finished all LED lights are on and it's not in ready state.
I have checked at the panel all zones are 0V. "closed"
Please helps I am new to this.
Thanks in advance.
NT
=== Program sequence =======
Reset the panel to default "short Z1 to PGM1"
Set time and date "trouble light off"
press * + 8 + [installer code]
press 000
press 0
press 11
press # twice
press * + 8 + [installer code] + 902
press 001
press 01 02 03 03 03 03 00 05
press # twice
All LEDS are on ???
Old 06-03-06, 03:31 PM
Received 25 Votes on 24 Posts
In programming, go to section 13, and turn on option 1. For whatever reason, a lot of installers don't use the end of line resistors on the DSC panels. On default the requirement is reactivated; this command turns off the resistor requirement.
Old 06-03-06, 04:08 PM
Thanks MrRonFL !!!
That's all it needs.
