CADDX 8980 - Access Program/Installer Code??
Old 06-24-06, 01:53 PM
A
I have a Caddx 8980 with the installer's manual, but no program code. Is there a way to default the panel or otherwise access programming via keypad?
Old 06-24-06, 03:47 PM
Received 126 Votes on 117 Posts
These things are a royal nightmare to try to default without having the current installer code. If the default installer code [9713] has been changed. The only possible workaround to get into program mode would be if you have one of the model 9050 LCD keypads. There is a way to get into the system programming with one of those, but only if the default coding on the keypad itself has never been changed.
Otherwise, you are stuck with "lucky guess". There's no hardware default function.
