First Alert Programming
Old 08-14-06, 06:28 AM
L
Just moved into new home with First Alert 110C alarm panel. We want to change some of the zone types and codes but no manual available. Now i found out these manuals are hard to find. Does this panel have any similarities to other panels and how do we reset the installer code?
Old 08-14-06, 04:56 PM
Received 92 Votes on 85 Posts
That one is a modified clone of an Ademco 4110(xl), as far as I can tell.
Old 08-30-06, 01:45 PM
navycop9545's Avatar
That one is really a 4110DL
Old 08-30-06, 02:01 PM
Smile
try to power down the panel. ac and battery. then hook them back up run to the keypad and press and hold the * and # key untell the display reads 20 or installer code( depending on the type of keypad you have) if this comes up your in good shape, if not, well you might be in bad shape. if it does say 20 type the new master code, then type *99 to exit program. this will allow you to re-enter program with master code+800
Old 09-28-08, 12:25 PM
T
oops posted in the wrong thread
