safewatch pro 3000 texting to a cell phone
Old 11-26-06, 05:22 PM
I have a ADT safewatch pro 3000 and I am trying to get it to text my cell phone using the paging mode(no monitoring service)
This is what Im doing and let me know what is wrong.
*41*(no monitoring #)
*42 (7-digit back door # to my voicemail)calls voicemail without ringing my phone
*43(10 digit cell #)my account #
*47 is set to 1
*49 is set to 6
*50 is set to 0
then I need a "1" entered to start text message mode.
The problem I seem to be having is the pauses and what field to have the "1" entered.
I can enter pauses in *42 (#+13) but in field *43 it will only let me type in my 10 digit phone number to get to my voicemail and no other numbers.
also does anyone have what each field means and what values should be in them?
Thanks,
Jim
Old 11-27-06, 11:03 AM
Received 279 Upvotes on 256 Posts
You are trying to do this in the wrong place. You want to try to do this in the pager programming area. (locations 160, 161, & 162).
The locations you are trying to use are made specifically for alarm receiver connections, and won't let you do what you are trying to do.
You cannot really pull off a text message, but you can get it to send info like a digital pager.
Old 11-27-06, 07:11 PM
MrRonFL,
Thank You,
I will use the plan sent in by Dave's post.
*160 (cell phone back door number)
*161 (#13#13 my cel phone number #13#13#13+1)
what field do I tell the system I want it to page/text me the alarm info? (opem/close/alarm).
Thank You,
Jim
Old 11-27-06, 08:10 PM
That would be location 162. That's where you select the events to be reported to the pager. The system uses a standard pager format.
Old 11-28-06, 08:55 AM
MrRonFL,
Thank You you have been extremely helpful.
In the *160 field what value do I enter for open/close/alarm page?
Is there anywere I can get a manual on all the fields?
Jim
Old 11-29-06, 04:57 AM
Hey,
I got it to work perfect thanks for all of your help.
Jim
Old 11-29-06, 08:53 AM
MrRonFL,
Can this system page more than one pager?
If so what are those fields?
Thank You,
Jim
Old 11-29-06, 09:14 AM
It will send up to 4 different pager outputs. Pagers 2-4 are locations 163 through 171.
The manual you want for programming this system is Honeywell/Ademco Vista 20p. It's a pretty common system, so a lot of manual vendors have it available.
Old 12-01-06, 05:37 PM
access the locations?
after reading these threads, how exactly do you access the locations on the safewatch 3000 to set it up to page? like the ones mentioned here.. 161, 162 ect.??
Old 12-01-06, 07:23 PM
Go to program: [installer code] + 8 + 00
From there you go to the programming locations by entering the * + location number.
If you are going to work with programming, you need the installer manual.
Old 12-02-06, 06:08 PM
Thanks
thanks....
Old 12-02-06, 06:33 PM
Installer Manual
i have looked online for a pdf of this manual.... where do you find this?
Old 12-02-06, 06:37 PM
If you websearch for Vista 20p installer manual this should be the second or third hit:
http://www.alarmeengros.com/installation15P.pdf
(the 15p and 20p use a common manual)
Old 12-02-06, 06:46 PM
thanks again
ok, i was already there.... my system wont open pdf files on the internet anymore for some reason.... the web page opens blank then says done,, i have adobe reader.... so i don't know... it wont even allow me right click and save it....
Old 12-03-06, 12:53 PM
exit mode
putting in the installer code +8 +00.... how do you exit this mode and get the system back to arming mode??
Old 12-03-06, 03:10 PM
Key in *99.
