Vista 20 and adding User Codes
Old 12-01-06, 06:15 AM
I have an Ademco Vista 20. I cannot get this panel to add additional user codes. I used the installer code +802 +new code to make a master code and this was confirmed by 1 beep from the keypad. I then tried using the master code +803 + new code to enter more user codes with no success or confirmation from the keypad. I have tried 804, 805, 806, 810, and many other user code "slots" without success. This essentially leaves me with only the installer code functioning as a useable code for arming and disarming. This is an older Vista 20 so if anyone has any information I am missing on programming new codes in I would be most appreciative.
Thanks in advance,
Jim
Old 12-01-06, 04:24 PM
Received 288 Upvotes on 265 Posts
The suffix is important!
It this is a Vista 20se (those little suffixes on the model numbers are _very_ important!), what you did was program a master code for partition 2 instead of partition 1.
Your correct keystroke should have been
[installer code] + 8 + 01 + [partion 1 mastercode]
Then to enter additional codes (03 - 16), you enter
[partition 1 MC] + 8 + (03-16) + [secondary code]
What you will need to do first, however, is to enter the partition 2 code + 8 + the slot numbers you already programed, one by one to erase those codes, or else the system will not allow you to overwrite a new code in those slots.
(sorry, there's no mass reset)
If the panel is neither a Vista 20se or a Vista 20p, there are a couple of older models that weren't that common, but also have a yet different code scheme.
Old 12-01-06, 06:41 PM
Thanks!!
I actually figured this one out about an hour ago and came back to post when I saw your response. It turns out that this is an SE (though figuring out exactly what model of 20 you have is a chore in itself) and you are correct. When I entered the master code under 01 all went well and I was able to start adding codes.
Thanks once again for the response and the help!!
Jim
