Vista10-se, getting started
Hi,
We recently bought a repossessed house that has a vista10-se but, of course, didn't get any info on it from the previous owners since we never met them.
Anyway, I've been doing some reading on this great site and have a few questions. 1. The control panel has an ADT logo on it. I believe I read in another thread that it may have some blocked access in it to prevent me from using it without subscribing to ADT, is that correct? If so, is there a way around it?
As well, I'm going to have to replace at least 1 wireless transmitter and wondering what the difference is between a 2 point and 3 point transmitter and how I know what I have/need. There are a total of 5 doors/windows on the first floor where it's installed, if that matters.
I looked at the schematic and notice that there isn't a phone line connected, which I would have disconnected anyway, which makes me think it was never active with ADT.
Any help is much appreciated.
I assume you are talking about the wireless window transmitters since you did not specifiy this.
Special three zone transmitter containing three separate contact loops. The primary loop is made to support normally open and normally closed applications as well as fast loop response time. The two auxiliary loops also support conventional normally closed contact functions.
Here's a link to the transmitter which I have installed with my Vista 10SE
http://www.safe-mart.com/ad58thzountr.html
note: you can find these cheap on Ebay :-p
Regarding ADT-
They (ADT) might have put a installer code on which might prevent you from doing anything to the system. A pro here can tell you what to do. Also, what model alarm pad do you have?
Regarding ADT-
If the system has never been connected to the telco lines, the odds are pretty good that you can access the panel to get control of it. To do anything beyond simply changing the user codes, you need an alphanumeric keypad (6139 or the equivalent).
