thought I had this figured out...then...
I have a DSC 632 that I installed in a new residence. Its wired and I ran the wiring while there were just windows and studs. I'm now trying to hook up the system and having difficulty with some things I don't quite understand. I had several zones wired and had the zones set up for either 01 or 03, with one 00 that wasn't used. I even had it armed at one point, but, I don't think the contacts are working becuase I couldn't trip the alarm. So I started disconnecting zones and disabling them from the keypad, still with no luck.
At this point, I wired a contact (surface mount, like I'm using for all windows and doors), directly to zone 1 on the board via a 2 foot piece of wire and taped the magnet to it. I enabled that zone only with 01 (so I could potentially hear it chirp before the siren goes off) and disabled the other zones with 00. BUT, I don't get a ready light! What gives?
I don't know how I can simplify my scenario any more, so I thought I would ask for help since I suspect there is something I'm not programing on the keypad that is causing me problems.
background: i did do a *8 master code 202 on the sole keypad I have. And I also powered down and disconnected the battery with each zone change I made on the wiring.
Mike
Mike
If I had to guess, you either have the zone programming incorrect, or you have the zone resistors in the loop when you _don't_ need them, or you left them out when they _are_ needed.
Programming section 202 is the zone disable. If you turned off the indicators for those 8 segments, then none of the zones will work.
What keystrokes did you try to use to set the zones for the system? I think that you may have either skipped a step, or added one that you didn't need...
I think you're right
I'll do a system reset to get all the defaults back and start over - I think I missed something in the first few steps when this didn't make as much sense to me (before I read the manual 15 times). I'll just try it again and make sure I'm using the right codes this time and also make sure I don't miss any steps...if I have the same issue, I'll be back!
Thanks,
Mike
Thanks,
Mike
