safewatch pro 3000 HELP!
I've been searching this entire board and I can't find the answer to my problem. A sensor was placed on my screen door (zone 18) and it broke and I decided that I didn't need it anymore. How can I permanently remove #18 from my unit so that I don't have to bypass it every single time I want to arm it? Please help! ADT wants to charge too much to do it. I think my unit is a safewatch pro 3000. The 6321 8 00 code works with it.
Thank you in advance.
If you have the programmers codes, try this.
go into programming
installer code 8 0 0 ??
press * 56
press *
press 18
press **
press 00
press *
press 1
press 00
press *99
and you should have it
go into programming
press * 56
press *
press 18
press **
press 00
press *
press 1
press 00
press *99
