Concord Express Sensors
Received 0 Votes
I recently had to do a full reset (mem clear) on the Concord Express unit.
Now none of my sensors work. They are not learned. How do I relearn to sensors? I know that you need to go into installer programming mode, but how do I gain access to that function? I have the Installer/Dealer code.
When I press 8+Installer code +00 on the touch pad on the wall it beeps and goes back to the time.
The reason for the reset I bought the house and did not have the master code. The system was armed to stay on accident.
Any help would be great.
Thanks in advance.
Concord Express system (60-806)
Thanks in advance.
Received 0 Votes
Thanks in advance.
Thanks in advance.
Received 0 Votes
I have 2 wall mounted touchpads. Both touchpads are a fixed display touchpad.It communicates by using indicator lights, lighted text, and an 11 character display.
Last edited by Ransign; 02-27-07 at 06:21 PM. Reason: Mistake about second touchpad
Received 0 Votes
I'm lost
I just purchased a new house with the same unit installed. I have the master code and an alphanumeric keypad on the wall, but when I try get into the programming mode it beeps and goes back to the time. Do I need to rewire the keypad at the panel to get into programming mode? If so, does anyone know the pin out for the programming connector?
Received 0 Votes
Look at the motherboard (in the can). Roughly in the middle of the board are two points labeled MEMORY CLEAR. You have to short across both points with a screwdriver while at the same time applying power (either AC or battery, battery probably easier since it's in the can already).
